TO-30 Electrical Woes
Brad (MO)
11-29-1999 05:39:05
Well, my TO-30 finally arrived this weekend and despite the fact that I spent three solid days awakening it from its 15 year slumber in November, it is again giving me problems.
It is still set up as the standard 6 volt positive ground generator system and depites the fact that nearly every wire has been replaced, it thoroughly enjoys burning up wiring.
Yesterday I had it running, it starts very easily, for about 2 hours with no problems. Then, three hours later when I drove it out of the barn to show a friend, it promptly fried the safety switch to starter wire (2 gauge).
Has anyone else had this problem, perhaps the voltage regulator? Thanks for any help you can give.
Ernie
11-29-1999 16:55:01
 Re: TO-30 Electrical Woes in reply to Brad (MO), 11-29-1999 05:39:05
Was it the starter end that got hot? If so take the starter apart and get a massive soldering iron, the old kind that you can heat with a torch and solder the main bus back onto the electrical stud. Happened to me when I let the stud turn a little tightening down the main cable. you don't wnat to put gas heat on the close soldering, hence the soldering iron.
