Redesigned Position Control
Pete@easttn
09-10-2002 07:35:47
third party image
Changed the way "Thang" works never liked it banging into my side. So shortened rod to 8 inches and now when raising rod goes under lift arm instead of raising up and hitting in my side. Shaped flat metal part in vise and then drilled one hole to mount onto side of lift arm, tightened this tight and raised lift all the way up and marked where the other hole was to be drilled. This leaves no room for the extra locking block but never used it anyway.
Gilby
09-13-2002 02:57:45
 Re: Redesigned Position Control in reply to Pete@easttn, 09-10-2002 07:35:47
Well guys I take my hat off to you. It's great to see others can think outside the square and come up with there own ideas for achieving a similar result. The Grey Ferguson Tractors where designed with a task in mind, today however things are a bit different and those of us who still use our Fergys know of the benefits of Position Control.
Check out this site with pictures of another way of achieving the same result. Judge for yourselves which is the neater less obtrusive system.
Link
Pete@easttn
09-10-2002 17:21:36
third party image
Ken,
I was just trying to show a better design, if I want to build a car General Motors would not stand in my way. But today most all cars look alike but some are designed better than others.
Ken
09-10-2002 18:11:10
 Re: Re: Redesigned Position Control in reply to Pete@easttn, 09-10-2002 17:21:36
Hi Pete, I wasn't aware there had already been an article written with pics, Jim pointed this out. (maybe I should get up with the times :) thanks,
Ken
Ken
09-10-2002 15:32:39
I believe in the past folks have avoided posting pictures of the Thang out of respect to Zane's invention and wishes. Some would copy or try to infringe on his original idea. I'm sure this wasn't posted in any way to do this, but it would be nice if it could be removed.
Ken
Ken
Jim W
09-10-2002 17:55:17
 Re: Re: Redesigned Position Control in reply to Ken, 09-10-2002 15:32:39
Ken,
There is a picture of the Zane Thang in the latest issue of the Ferguson Heritage magazine from England. They have a little write-up saying how handy it is and the picture makes it quite clear how it works.
Cat's out of the bag, as they say.
Jim W
PS I got one but then never mounted it as I (so far) only have implements that need to be up or down. I guess that means I need more implements, right?
Ken
09-10-2002 18:07:42
 Re: Re: Re: Redesigned Position Control in reply to Jim W, 09-10-2002 17:55:17
Jim, thanks for the heads up, I was just watching out for Zane, he is such a nice guy, although I knew there was no intention to undermine his work.
The best part is that it works so nicely, and makes tractoring more enjoyable. thanks Jim,
Ken
Frank
09-10-2002 11:08:08
Pete,
Could you post a photo? It sounds interesting.
Regards
Frank
Pete@easttn
09-10-2002 17:24:23
 Re: Re: Redesigned Position Control in reply to Frank, 09-10-2002 11:08:08
Frank,
a picture is with message it's in .jpg format
