Tea front axle bolts
MOrty-Alberta
09-05-2002 12:02:14
I was using my tractor on the weekend and noticed that one of the bolts holding the radius arm to the front axle was broken, I alertly measured it and then came back to the city and lost the note. Does anyone know what size and length these are ? and what strength bolts they should be ? thanks in advance
Joe Wallace
09-06-2002 04:57:44
 Re: Tea front axle bolts in reply to MOrty-Alberta, 09-05-2002 12:02:14
5/8" x 5 1/4" fine thread, heavy hex (larger than modern head and nut).
I had to resort to 5/8 x 6" with normal heads, and I put washers under the heads and nuts.
I think you should not get a high grade; better the bolt wear than the radius arm or axle.
Jim W.
