No choke needed
Paul in NY
09-03-2002 21:00:40
I decided to ask the experts. My tractor is running adequately but not the smoothest. When I go to start it, I never have to pull out the choke and it starts right up. I was thinking- could this be a diagnostic symtom as to why it's running a bit rough? Thanks Paul
Phil (VA)
09-04-2002 08:20:44
 Re: No choke needed in reply to Paul in NY, 09-03-2002 21:00:40
Could be that it is running too rich, which could be too much gas or too little air. Check your plugs. Are they black from soot? If so, then probably a little too rich, although slightly rich is ok and preferable to being too lean. If you are running too rich, make sure your air cleaner is functioning properly. Then check the idle mixture. Archives on this site will give you plenty of advice on that. If still a problem, look at carb. Is choke linkage out of adjustment? Perhaps choke plate is partially closed even when choke rod is pushed in? If none of that "exterior" stuff helps, you may need to rebuild carb. Of course, you could have an electrical problem too, but you didn't give enough symptoms to comment further.
