Pissed off
bosshog
08-29-2002 07:48:01
i have a 1951 TED20 and i have been trying for about a month to take the steering wheel off. The thing will not budge even though it has been battered with numerious hammers, even the WD 40 wont soak through to try and relieve it. I have no way of getting my hands on a set of gear pullers and i have run out of ideas.
Norm
08-30-2002 18:54:15
 Re: pissed off in reply to bosshog, 08-29-2002 07:48:01
Hi there, There is a post somewhere here that mentionned using a nut being same size as original and a bearing slightly larger than the nut size opening. You'd weld them both ending with the bearing protuding slightly below nut surface. Then you'd tighten tight until bearing contacts wheel shaft surface and give it a few good hammer blows then voil�. Now I'm not speaking from experience but it does sound plausible.
On a sidenote I never figured why WD40 made so much inroads in the rust inhibitor market, it is only an oil dispersant pure and simple. Great for starting my Elan Skidoo on the first cranking of the season though . :)
Good luck
Bill Mc
08-29-2002 18:17:36
Rent a puller from your local auto parts store. Be sure to tell them it's to remove a steering wheel(you need a split ring to grab the underside of the spokes). Also side impacts from a rubber mallet help set up a vibration in the shaft.Please NO BAD WORDS kim the board moderator will get upset.
Bill Mc
Phil (VA)
08-29-2002 12:13:25
PB Blaster is good stuff and might help. Squirt it on and let it sit for awhile. WD40 is no good for that. Also, heat might help, even if just from propane canister.
Matt Jones
09-14-2002 03:40:12
 Re: Re: pissed off in reply to Phil (VA), 08-29-2002 12:13:25
Going to need heat and a puller if neither are avaliable and your going to replace it cut it of ( hacksaw ) new steering wheel around $35.00
Ray,IN
08-29-2002 21:09:28
I would'nt use a torch, the heat/flame will ruin the bakelite wheel material. I'd use PB blaster and the steering wheel puller as posted. WD40 is about like using kerosene and has little lubricating qualities. Until recently it did not say anywhere on the can it would even lubricate. It will however, burn readily and flash when subjected to a spark, high heat, and flame; thus making it good for a starting fluid.
alton
09-02-2002 07:42:39
 Re: Re: Re: pissed off in reply to Ray,IN, 08-29-2002 21:09:28
My NAPA store rents sterring wheel pullers. check with the one near you. Hammering could damage the bearing in the gear box. the puller is the safest way to go.
