Overhauling TO-30
Don
08-28-2002 15:25:35
Can anyone tell me if it is possible for someone with little experience to overhaul a TO-30 engine using one of the videos offered by ytmag? I would like to restore this tractor myself, starting with the engine, but don't know if I should attempt it or not. Any advise would certainly be welcome!
scott morrow
09-01-2002 20:23:33
 Re: Overhauling TO-30 in reply to Don, 08-28-2002 15:25:35
Go for it these are simple motors and fergusons have a wet sleeve so you don't have to bore out the block. Get your self a new IT manual this will give you tear down and put together info if you run into trouble ask questions here.You will feel great when your done.
RayOh
08-28-2002 16:02:15
The First Engine I Did Was In A 1974 Corvette & It Was A 454. I Did It All But The Machine Work & Its A Great Feeling When It Fires Up The First Time & You Can Puff Out Your Chest & Say I Built That Motor.What You Dont Know, Ask Cause Everyone Started Right Where You Are Starting. Good Luck
Don
08-28-2002 18:55:44
 Re: Re: Overhauling TO-30 in reply to RayOh, 08-28-2002 16:02:15
RayOh, thanks for the support!
