TO 20 TRACTOR WON`T TURN OVER
MIKE
08-23-2002 17:42:39
6 VOLT POSITIVE GROUND, SWITCH METERS OUT OKAY. HAVE NO VOLTAGE ACROSS ALTIMETER TERMINALS WHEN SWITCH IS TURNED ON. PLEASE HELP.
THANKS,
MIKE
Tex Ferguson
08-23-2002 19:31:32
 Re: TO 20 TRACTOR WON`T TURN OVER in reply to MIKE, 08-23-2002 17:42:39
Hey Mike, I used to get my wife to pull start my Ferguson with an F-150; that works pretty well.
Need more info to be able to make any suggestions:
is yours a completely stock setup? did you make any changes before this first happened? Do you hear the solenoid clunk or does your meter show a current at the solenoid when you try the starter button? I recently replaced my aftermarket solenoid because it quit. Let us know some more details, or if you have fixed it, let us know how you did it. Good luck! Tex
mike
08-25-2002 16:06:34
 Re: Re: TO 20 TRACTOR WON`T TURN OVER in reply to Tex Ferguson, 08-23-2002 19:31:32
TEX, THANKS FOR THE REPLY.ON MY TO 20 IT DOESN`T HAVE A SOLINIOD.TRACTOR WAS RUNNING FINE THREE WEEKS AGO.WHEN I TURN THE SWITCH ON I CAN READ SIX VOLTS GOING THRU THE SWITCH TO THE STARTER BUTTON AND TO THE COIL AND TO THE DISTRIBTER CAP.BUT READ NO VOLTAGE AT THE ALTIMETER GAUGE.I REPLACE THE COIL, STARTER, REGULATOR,STARTER BUTTON AND ON OFF SWITCH A YEAR AGO.I THINK THE PROBELM MAY BE IN THE VOLTAGE REGULATOR, BUT NOT SURE HOW TO DETERMINE IT.I CAN PUT THE CHARGER ON THE BATTERY, AND STILL NO VOLTAGE AT THE ALTIMETER
