TO35 Electrical Help
Rob Pearce
08-22-2002 15:12:39
As usual I know enough to be in trouble!! I need some help. I recently got a TO35(it came with the place I bought). It was very sick, but I got it running. I replaced the starter, generator, regulator, selenoid, and put in a tune up kit, and it is running much better. It was wired as a 6 volt negative ground which is the way I replaced everything. My question is the manual I have says it should be wired as a positive ground. It seems to work fine as a negative ground,the only problem is it charges at 20 amps at full trottle and stays there, the regulator never cuts out the charging. Have I messed something up? Also, which way should the hand trottle be moved to increase rpm, right now I have to move it from right to left (push) the manual says it should be move from left to right (pulled toward driver). This poor old tractor has had lots of "modifications" to it. Any help will be appreciated
