Pertronix electronic ignition
captain twinin
08-21-2002 16:44:01
anybody out there have any thoughts about pertronix electronic ignition systems? ie do they work and are they worth the money. also are they easy to install
NCtim
08-27-2002 04:40:05
 Re: pertronix electronic ignition in reply to captain twining, 08-21-2002 16:44:01
I have one on my '49 TEA and it works beautifully. It's never failed to start the first time, even after sitting for three months and the battery low.
Takes about an hour to install (I have a front loader I had to work around).
billh
08-21-2002 17:49:30
I put one on my TO-30. One of the best things I have ever done. Easy to install, doesn't change the stock looks. Made my tractor easy to start, and no more points.
Lennick
10-26-2002 13:46:39
 Re: Re: pertronix electronic ignition in reply to billh, 08-21-2002 17:49:30
How does this compare to the Genesee unit on a front mount dist. ? They make one that fits ..
captain twining
08-22-2002 08:14:35
hey bill,
do you remember the protonix part number?-can't find the number on my dist
billh
08-22-2002 09:27:39
 Re: Re: Re: pertronix electronic ignition in reply to captain twining, 08-22-2002 08:14:35
I got mine from Genesee products July of 1999.
the part number was 1143P6. Ignitor kit 6 volt positive ground. At that time the cost was $96.
I also got a 30kv coil part # 30010 for $27.
I was told to replace the coil in this application.
rod
08-21-2002 17:10:40
has one on a JD A took about 5 mins to install and worked fine still on tractor when I sold it.
regards
rod
