TO30 pto slow down
Terry Serur
08-15-2002 04:03:32
The pto slows down when I am mowing in heavy grass. It does this spasmodically. I am guessing that the clutch must be slipping. If this is correct, is there and adjustment that can be done with out breaking the tractor in half? Thanks.
Ray,IN
08-15-2002 18:31:50
 Re: TO30 pto slow down in reply to Terry Serur, 08-15-2002 04:03:32
You should smell it if the clutch is slipping. To adjust the tractor clutch, insert a bar into the hole in the clutch shaft where the clutch pedal attaches. Loosen the pedal clamp bolt, and while holding the slack out of the clutch, adjust the pedal to have 3/16" clearance between the pedal bar and the foot peg. Tighten the clamp and recheck the 3/16" clearance. If this does'nt correct the problem you may need to replace the clutch.
