To-20 Running poorly
Clint
08-10-2002 16:04:16
O.K. here is the deal..... I have a TO-20 that runs fine during normal use such as bushhogging etc. But when i attach a finish mower or a plow (one or two bottom) it dont do a thing, also at startup and under load it lets out bluish black smoke. anyone got any suggestions.
Norm
08-10-2002 19:16:31
 Re: To-20 Running poorly in reply to Clint, 08-10-2002 16:04:16
Hi Clint, Assuming that you have all the basics covered such as plugs condition and gapped, Gaz glass bowl & brass filter cleaned along with air cleaner and points checked, next would be probably a compression test which may reveal the root of the bluish smoke. Also checking your valves gap and adjusting them might reveal more. In other words if you have already done a lot of these regular maintenance checks perhaps you could try to explain the symptoms in more detail.
Btw do the valve adjustments before compression test. Good luck.
Norm
