TO 20 clutch
dave
08-08-2002 08:17:06
Just got her running after two years down. Clutch initially does not work--must slam in gear at low rpm and depressing cluth will not stop tractor--after a bit, clutch starts working ok but not 100%--still grinds a bit to get in gear but will let-off when depressed. Any input would be appreciated.
Larry in Missouri
08-09-2002 08:16:24
 Re: TO 20 clutch in reply to dave, 08-08-2002 08:17:06
I presume you've checked the clutch adjustment? If not, please do so! It could something as simple as the adjustment not allowing for full disengagement of the clutch. If it does it and is properly adjusted, I would agree that the clutch plate may be sticking a bit to the flywheel due to rust or corrosion. But slipping the clutch for a bit should clean that up. Good luck!
Larry in Missouri
Duner Wi
08-08-2002 12:55:57
Flywheel and clutch surfqaces probably rusted some. Slip the cluth some for a couple of minutes and see if it improves. This can be done a bit at a time. No need to get anything hot.
