T020 Lift control for 3pt.
Dennis
08-07-2002 16:08:07
What connects the lower control bar to the pump control. I took the side cover off but being full of oil I can only feel the connection. The bar has a hole which allows another part through it. This is all at the pump. I put the part in and ran the hitch but it fell right out. This !@#$%^&)% tractor only works when I'm not using it.
rod
08-08-2002 05:11:57
 Re: T020 Lift control for 3pt. in reply to Dennis, 08-07-2002 16:08:07
send me your email and I will scan a parts pic and send it to you.
most likely the pin has fallen out or broke and is in bottom of casting. Also there is a spring at the top that might be off.
regards
rod
