MF35 Fuel Tank
Randy
08-03-2002 12:24:38
Folks: How does the tank hold some gas in reserve? How does turning the tank outlet valve 2 turns make it full open from the main tank, and then going full open on the valve(another 1/2 turn) bring in the reserve fuel? Does the tank have a baffle or a depression in it? If I open the reserve while the main tank is down to a low level , can the reserve run out of gas while while the main still has some? Thanks!
Fergie Fan
08-04-2002 12:01:47
 Re: MF35 Fuel Tank in reply to Randy, 08-03-2002 12:24:38
Intake pipe has 2 inlets , one higher than other , we always found it was better to keep valve open all the way , that way you don't get a build up of gunk in bottom of tank . But the odd time you will run out of gas . Get yourself a Fergie wrench , it has a dipstick stamped into it , use it if in doubt.
