Stuck rear retainer
Terry
07-26-2002 16:40:09
I am in the process of repacking my rear bearings on my to35. One side went smooth, the other I can't get the axle assemble separated from the rear. All retainer nuts are off (even a couple complete studs), the brake rod has been unhooked with clevis removed. I was not able to remove the brake drum on this side (screws stuck). Anyway I have beating with a heavy hammer and block of wood with no good results. I am beating on the retainer itself, but am afraid to beat to hard a break the retainer. Could I heat at the point of separation or would I damage anything internally? Appreaciate suggestions! Also what amount should be put in (grease)? Thanks
Terry
07-26-2002 18:19:14
 Re: Stuck rear retainer in reply to Terry, 07-26-2002 16:40:09
After much more pounding I have been able to begin to get it separated, I squirted Liquid Wrench down and around and should be able to pound in all the way out in the morning. Still would like to know what is the proper amount o grease to pack in? Is there such a thing as too much? Thanks
