Please help
Rick
07-21-2002 02:59:21
i own a restored 1951 ferguson TED20, the problem is that i would like to replace the old chrome collar, nut and washer for the steering, this involves removing the steering wheel to fit the collar. The problem is that i cannot get the steering wheel off and i was wondering if the steering wheel should just lift straight off when the nut and washer have been removed. Is this the case or is there a special technic for removing it. i would be greatful for any help
Chuck (CA)
07-22-2002 22:39:15
 Re: please help in reply to Rick, 07-21-2002 02:59:21
In the past, I learned the hard way (not on a tractor) to loosen the nut, but not to take it off all the way until the steering wheel worked loose. I got a little too enthusiastic on tugging on the wheel and actually chipped a tooth when it came loose. Leaving the nut on keeps the wheel from launching.
HTH
Chuck
Phil (VA)
07-22-2002 06:16:34
Bill is correct. It will come off. PB Blaster may help. Soak it with PBB and let it sit overnight. A puller may help, but tapping from underneath usually works.
Bill MacPherson
07-21-2002 06:05:55
Use a gear puller , go slow , tap gently from underneath , use wd-40 or equivalent before starting to work to release rust . With a little patience and effort , it will come off---Bill
