Throttle problems
Steve
07-16-2002 18:34:21
While I'm using my TO-30, the throttle lever rides up and forces me to hold it down to maintain constant RPM's. Does this mean I have to rebuild the governor or is there some adjustment I'm missing?
Ray,IN
07-16-2002 20:13:13
 Re: Throttle problems in reply to Steve, 07-16-2002 18:34:21
This was answered in previous posts. The cork material(friction disk) between the round plates under the RH side of the dash is probably bad and should be replaced. Loosen the clamp holding the spring tension on the throttle rod just between the battery and the oil cleaner unit. this allows you to pull the plates apart and inspect the cork. If it is hard, oily, or missing you must replace it by cutting out a new one from sheet material. Remove the bad one and clean the surfaces of the plates. Cut one side of the new one to allow insertion without disassembling the entire linkage. Re-tension the spring and tighten clamp block. The governor linkage seldom needs reset, just oiled occasionally. I would'nt attempt to reset the governor without an owners manual, it's touchy.
Ken
07-18-2002 09:31:42
 Re: Re: Throttle problems in reply to Ray,IN, 07-16-2002 20:13:13
Ray,
Just a light oil?
Ken
