TO20 valve adjustment
Dubya D
07-11-2002 17:16:37
I've noticed a ticking coming from my TO20. It sounds like the valves to me, but I'm basing this on my experience with car engines. Is this normal? If the valves do need adjusting, do I have to remove the gas tank? The tractor seems to run fine otherwise.
Ray,IN
07-11-2002 20:38:42
 Re: TO20 valve adjustment in reply to Dubya D, 07-11-2002 17:16:37
A small amount of rocker arm noise is ok, but a reajustment can't hurt. The gas tank must be removed to permit removing the valve cover. Adjust valves to 0.013"minimum cold; 0.015"won't hurt anything. Do not adjust too tight, it'll cause hard starting and you may burn the valves.
