TO20 pto removal
Hunter
07-10-2002 13:17:44
Is there anything other than taking the 4 bolts out around the pto that needs to be done to take the pto shaft out? Thanks!
John, IN
07-10-2002 16:14:49
 Re: TO20 pto removal in reply to Hunter, 07-10-2002 13:17:44
Yep, drain the oil, or you can put the front end in a ditch. I would drain it just to see how much crap is in the hyd. system.
Ray,IN
07-10-2002 19:51:08
 Re: Re: TO20 pto removal in reply to John, IN, 07-10-2002 16:14:49
John's correct. Remove all 3 drain plugs or you won't get the settlings out of each compartment. Refill with 80/90wt. straight mineral oil (MF 1103,I think). Remove as you indicated; check the bearing before pressing onto the new shaft.
