Will a Dearborn Loader fit a TO-30?
Canute
07-09-2002 18:05:41
As the title of the message implies, I'm wondering if a Ford loader off an 8N will fit the Ferguson. Can anyone help me on this?
Thanks!
Bill In Leland
07-10-2002 17:11:24
 Re: Will a Dearborn Loader fit a TO-30? in reply to Canute, 07-09-2002 18:05:41
I would just like to say dont mount the loader ! My grandfathers to 30 wich I just reiceved is trashed do to a loader . I lifted a small bucket load of stone . It broke the front axel both moter mounts cracked the loader and split the pump. So please dont do it.It is not worth trashing a great tractor. BILL
Phil (VA)
07-10-2002 06:48:30
I have a Dearborn loader that came off an 8N and I mounted it directly on a TO-30 and it fit perfectly. It will not fit a TO-35, however, as I tried that. The 8N and the TO-30 apparently are exactly the same measurements from axle to axle. The one I have has a front pump and a stinger to the pulley. It also bolts to the rear axle using the fender bolts, although I replaced my fender bolts with new grade 8 bolts. I did not put the fenders back on. The holes in the front bracket needed a little coaxing, but they were ok. Loader works fine. Hope that helps.
