To-20 choke valve return spring
Steve Putman
07-01-2002 11:13:01
Anybody know any tricks for replacing the choke valve return spring? It's a little coil spring that works in torsion on the back side of the Marvel-S carb on the choke valve shaft, and it looks like I have to take apart the carb to get the new spring on. I will if I have too, but I'd rather not.
Thanks
tokruys
07-02-2002 03:45:06
 Re: to-20 choke valve return spring in reply to Steve Putman, 07-01-2002 11:13:01
The only way I can imagine to do it is by taking the carb off and removing the choke plate. This will allow you to pull the choke shaft out and replace the spring.
