TO35 Deluxe Hydraulics
Jer
06-22-2002 19:21:52
I have just aquired a TO35 Deluxe and am having problems with the lift. While it is functioning it just cannot lift heavier implements. I assume this is a pump or lift piston problem. The question I have is more about parts to repair this. All the searches on the webI have done show parts for tractors with S/N > 174000. While the S/N plate is missing from this tractor, I assume it is about 145000 made in about 1955. THis is based on the engine block S/N of z135A600 and the green base paint on the engine.
Can anyone help with information on part sources for an older tractor like this? Any information on better identifying the model year would help also.
Thanks for your help.
steve19438
06-24-2002 07:13:45
 Re: TO35 Deluxe Hydraulics in reply to Jer, 06-22-2002 19:21:52
where are ya located???
i know of a couple of places in PA that can help you.
steve
Jay Ford
08-26-2002 09:15:27
 Re: Re: TO35 Deluxe Hydraulics in reply to steve19438, 06-24-2002 07:13:45
I have a 1958 TO35 That is doing the same thing when it is hot. When it is cold the hydraulics work great. The problem got better when I changed the fluid with the Ferguson 80/90 oil, but still will fade or not even lift. I can find the "sweet spot" on the lever that will lift but that may take a minute of moving it up and down. I don't really know where to start either. If you have soovled your problem, let me know.
