TEA20 convert to alternator
laurie smith
06-11-2002 14:34:14
Any tips on converting a tea20 from geny to alternator
gerry
06-29-2002 17:46:52
 Re: TEA20 convert to alternator in reply to laurie smith, 06-11-2002 14:34:14
tried that web site and wasn,t avabile any suggestions as im try to go with an alt.too
Laurie Smith
06-29-2002 20:23:53
 Re: Re: TEA20 convert to alternator in reply to gerry, 06-29-2002 17:46:52
My conversion was relativley easy. Bolted on a selfregulating alternator($40 AUD at the local wrecker) and ran a suitable wire to the + side of the battery via an ampmeter, ran a wire to the igniton switch via a light to excite the coil (one with a bulb not a LED) and cut the power wire to the old regulator. The light goes out when the alternator starts charging. Had to find a suitable pulley for the alternator and get it machined to fit and add an extension bit to the belt tensioner. You may be lucky and find an alternator with a suitable pulley allready on it. The pulley size is not critical as long as it fits the belt. It worked for me Laurie
John, IN
06-12-2002 17:44:54
Go tho this link and I can send you a print of how I did my TO20 if you like.
http://www.ytmag.com/articles/artint131.htm
