What model do I have and were can I find parts
Jerry Groom
06-10-2002 17:33:58
I beleve it is a TO20 it has TO 501 A stamped in the casing under the seat and I need a oil pump and a Thursh washer for it the main bering is a little worn but I think it will be OK. I need gaskets oil filter ect. this is my first old tractor so wish me luck. Thanks
Ray,IN
06-11-2002 21:08:00
 Re: what model do I have and were can I find parts in reply to Jerry Groom, 06-10-2002 17:33:58
The nameplate will be just above the steering wheel if present. You may trace the serial number through the link at the left to find the mfgr year. If the plate is missing, copy the casting numbers from the engine, trans, diff, etc. and visit a MF dealership. With some charm and diplomacy you should get them to trace the numbers to find the information. For parts, follow the search box at top left. Harry Ferguson is not listed, but follow massey to your tractor and parts; OR you may click on tractor parts under the "marketplace" box to find a list of suppliers. For used parts try this list:
Gary Johnson
05-20-2003 16:35:05
 Re: Re: what model do I have and were can I find parts in reply to Ray,IN, 06-11-2002 21:08:00
My model number says TO 90324. What year and make is this. The plate also says Harry Ferguson.
