Joe: Actually, it was a combination of a bunch of half-bad things. The tractor is getting better and better with everything I fix. First, I did a full tune-up (cap, rotor, plugs, wires, condenser, points)- then, it turned out that the wire from the distributor to the coil was grounding itself out at the distributor connection(took me a while to figure that out). I replaced the coil with a really good ($45) one, and now the tractor is working so much better. Turns out my alternator was bad- I just got a new one today. Now I just have to wait for my rebuilt carb to come (not only is the carb on the tractor in bad shape.....but it's the wrong one!).....and while I'm waiting for the carb, I'm gonna adjust the valves- then the tractor will be 100% (surprisingly, my fuel line wasn't clogged!) I knew when I got the tractor that the motor was sound- and that the tractor just needed "little things"- but man....it needed EVERY little thing! This has really taught me not to overlook the simple, obvious things. I used to be in the auto salvage business- and by the time a car got to me, it was never just wires or spark plugs causing its' problem- but always a head gasket or cam bearings or blow-by- major stuff. So, I got in the habit of always discounting the little things, and always aiming right for the major things. I have to remind myself that not everything out there is junk!
