Help with TO-35 12V conversion Tach hookup. Also throttle cable help.
Dave
06-06-2002 19:01:08
I have a TO-35, ser# 169413 ('56 model) that has a 12V conversion with an alternator. It was already converted when I bought it.
The original tach is disconnected, and the cable is routed to the right side of the engine block, but not hooked up to anything. From a previous post, I saw that it was originally hooked up to a hole in the back of the 6V generator which I obviously no longer have installed. does anybody have any knowledge of how to get the tach functional with my 12V conversion.
Also, the throttle cable is disconnected from the normal throttle lever by the steering wheel, and is instead hooked up to a cheap push lawnmower type throttle lever that is just dangling off the side - also was like this when I bought it. Can any body offer advice on how to hook back up to the regular throttle handle - I'm not sure if I have to buy a new throttle cable or not. Not even sure why it would have been disconnected in the first place.
Thanks for any help you can offer.
