Transmission oil
brian graves
06-04-2002 21:47:14
can someone tell me what type of oil or trans mission fluid i should use in my to20 fergison tractor is it 85/90 weigt oil or trans. fluid
Phil (VA)
06-06-2002 06:45:53
 Re: transmission oil in reply to brian graves, 06-04-2002 21:47:14
As the other Phil says, 90 wt. mineral oil is what the manual says. I believe what is labeled as GL-1 is same stuff. Don't use GL-5 as supposedly that damages pump. Takes 6 gallons. Three drain holes, one fill hole. Hope that helps.
phil fenner
06-06-2002 16:52:55
 Re: Re: transmission oil in reply to Phil (VA), 06-06-2002 06:45:53
No argument with GL-1. If you want the scoop on xmissionoils go to the ford 2n3n8n disscussion forum of this site and look at message dated March 29 by llamas. Make your head hurt.
Phil F
phil fenner
06-05-2002 14:20:43
90 wt mineral oil M1103 from a MF dealer. Check some previous posts of last month for more discussion
