No start-simple fix
tom krizman
05-27-2002 18:41:27
F-40(gas) sat all winter, as it has for the last two years, and it always started right up. Not this time. Went to the Massey Dealer in Pickford Michigan(Skinners)and talked it over. Went to their mechanic and he said that on the older tractors that sit for long periods(2 months)the first thing to check is the points. $8.95 later with new points/condenser and rotor and new plugs-not included in the $8.95 I was up and running. Just thought I would pass on this simple solution. (First thing I checked was gas flow)
Drizler
06-02-2002 23:41:56
 Re: No start-simple fix in reply to tom krizman, 05-27-2002 18:41:27
A lot of mechanics recommend B-12 for engines that have to sit seasonally. It cleans out the varnish gunk somehow and keeps things freed up in the carb. You can get it in Auto Zone and related type stores, probably even Walmart. I hear many people use it in boats that sit all winter.
Dennis in Ma
05-28-2002 09:05:42
If you left gas in the tank with no stabilizer, I'd bet the gas has gone bad. It's happened to me twice. Never again. I use Stabil every fall in all my engines. The tractor gets used all winter plowing so it isn't as much of a problem as the lawnmover, generator, etc. If this is the case drain it all outof the tank and sediment bulb, blow out the line, drain the carb and if you're lucky you won't have to take the carb apart. Dead gas just won't burn.
