TO30 Front Loader Pump BUZZING!!!!
Mike
05-20-2002 19:35:39
This spring when I went to turn over the compost pile, the hydrolics started to make a buzzing noise. The vibration travels up into the hand controls for the bucket. Also the bucket lifts alot slower. Its not smoth like before. Is the pump about to die? The front piston did leak a little while in the barn this winter but I added a gallon of fluied to it and it did'nt change. And get a load of this: When I put a load of dirt in the bucket, It lifts smother and the buzzing stops????? ?????
Dennis in Ma
05-22-2002 11:30:27
 Re: TO30 Front Loader Pump BUZZING!!!! in reply to Mike, 05-20-2002 19:35:39
still sounds to me like you're low on fluid. It may have leaked more than you thought. I just had the same problem after replacing a ram. When I changed it I thought I replaced enough fluid. Got same symptoms as you. I added another 1/2 gal and problem solved. Don't worry, you can't over fill it unless it runs out the fill pipe !!
mike MA
05-23-2002 15:30:09
 Re: Re: TO30 Front Loader Pump BUZZING!!!! in reply to Dennis in Ma, 05-22-2002 11:30:27
Dennis YOU DA MAN!!!! That was exactly what was wrong. I added three quarts and bingo! I'm back in busness. THANKS A MILLION
