TO-20 brake drum question
Ken Shine
05-17-2002 13:39:30
I want to install new brakes on my Fergi but I can't get the right side brake drum off. What is the trick to doing this little chore.
Peter, U.K.
05-18-2002 02:55:10
 Re: TO-20 brake drum question in reply to Ken Shine, 05-17-2002 13:39:30
If you dont have a large puller as suggested, once you've taken out the securing screw and backed off the adjuster, try tapping gently around the circumference of the drum with a hammer and soft drift. Not too hard or you may cravk the drum. This has always worked for me.
Dan in LA
05-17-2002 16:40:21
Ken,
When you say you can't get the brake drum off, I'm assuming that you have already removed the two screws on the outside face of the drum and have loosed the adjusting mechanism as far as possible. I have seen a stuck brake drum on another model tractor removed with a large 3-jawed gear puller. You might could rent one and try that. Hope that helps.
Dan
