What's This Valve For?
Richie MaGoo
05-15-2002 19:31:36
Just purchased a '49 TO-20, and while doing some preventative maintenance on it today, I noticed that there is a brass valve sticking out of the engine block, just under the carb. -it has a little handle, apparently to open and close it (there is an outlet). What could this be for?
Also: Is it possible to widen the stance of the rear wheels on these tractor....and if so, how does one accomplish this?
Thanks!
F. Light
05-16-2002 08:37:03
 Re: What's This Valve For? in reply to Richie MaGoo, 05-15-2002 19:31:36
I thought the valve was for getting air out of the block to prevent an air lock in the coolant system when the block was completely drained, or to let air in to completely drain the system. The theory was when water/antifreeze comes out of the valve, you're full and won't get hot spots when starting with new coolant or after a rebuild (sorta like the little hole in an auto thermostat). ??? I don't know, cause I've never had a Ferguson block to examine!
Richie MaGoo
05-15-2002 20:38:50
Thanks guys! I kinda suspected it was a drain of some sort....but thought it was too high up for that!
Ray,IN
05-15-2002 21:03:36
 Re: Re: What's This Valve For? in reply to Richie MaGoo, 05-15-2002 20:38:50
Visit a MF dealership and purchase a reprint owners manual. The wheel widing procedure is there along with lots of other needed information.
Rusty
05-15-2002 19:48:42
If you open the valve water should drain out the block. The valve may not work. Mine is stuck. You should be able to widen the back tires by tuning them around or repositioning the rim on the disk.
Ford Man
05-15-2002 19:47:24
The valve is to drain the coolant from the block .
Ford Man
