NEED ADVISE
jim in ky
05-15-2002 08:14:30
I have a TO-30 with a badly cracked block, water running in all cylinders. I have found a few repaired blocks but none of the places would stand behind them. They say that this is a weak point in these blocks and that they will crack again sooner or later no matter what you do.Finding a good block that has not been cracked has proved to be impossible for me so far.My question is if what they are telling me is true am i going to be doing this again in just a matter of time? What should i do? Thanks for all advise
Bill MacPherson
05-17-2002 15:04:08
 Re: NEED ADVISE in reply to jim in ky, 05-15-2002 08:14:30
Try some Canadian suppliers , not only cheaper but a LOT of Fergie parts north of border , look for Fawcetts in St. Mary's for a start.
Jim W
05-15-2002 13:54:12
I recently heard that the Z134 engine (from a TO35) had a heavier block and didn't suffer from these problems.
I don't know if it would fit, but if so, that might be an option for you.
Mark Hendershot
05-15-2002 08:42:50
They all do not crack! Mine has no cracks and is 50 years old and the block I removed from my TO-30 which punched a hole in the side of the block is not cracked. One day I will repair the 1 inch hole and sell the block. They seem to be hard to find not cracked tho. Mark H.
