Maybe Something Helpful I Hope
C.T.
05-02-2002 18:46:24
Ok i bragged on my TO 20 in an earlier post and see what it got me?Well the ole hag kinda let me down.The tractor would start up and run for about a minute with the idling flucuating.I took the carb off three times and cleaned it out and it still did the same thing.Finally i said the heck with this,sounds like it was starving for gas so i went and bought a complete carb kit and installed it.Guess what?Still the same ole problem,i decided to to take the distribitor cap off and check the points.They looked good.By this time i was banging my head(not actually)so i decided to spray some carb cleaner down in the distribitor under the points plate and that cured my problem.I take it that something was jumping fire.I had a tractor mechanic tell me that if it wasn't the carb then i might want to pull the timing cover off and check the governor.Boy am i glad that i used my shade tree technology.
Phil (VA)
05-03-2002 06:49:49
 Re: Maybe Something Helpful I Hope in reply to C.T., 05-02-2002 18:46:24
It's been said before, but maybe bears repeating that most "carb problems" are in the ignition. Thanks for the post.
