TO35 deisel
jethro
04-30-2002 20:52:28
I have a feguson 35 tractor with a model # TO35 and serial # sdm195972, it has a 4 cylinder diesel. What kind of diesel is it, I've been told its a perkins and I've been told its a continental, plus where can I find an oil filter and a fuel filter for it. Please e-mail me as well as posting answers at [email protected]
Thank you
Jack in NB
05-01-2002 04:58:38
 Re: TO35 deisel in reply to jethro, 04-30-2002 20:52:28
The engine is a Standard 23C (2.3 litre displacement). Made by Standard Motor Co. A good solid engine, about 35 hp, replaced about '59 with the easier starting Perkins 3 cyl, about 38 hp.
The oil filter is MF part no 894976M1, Wix 51302, Fram CH820PL. The IH B414 D and 424 take the same filter.
The fuel filters on mine were cartridges inside heavy metal cans. The longer filter is about 3 1/2 h x 2 3/4 with a 1 5/16 hole. MF 1850450M2, Wix 33194, AC FF23, Fram C11816 PL.
The wider one contains a metal cannister, 2 15/16 h, 3 7/16 d, about 3/4 holes. MF 1012006M2, CAV 44 or 7111/44. Wix 33114, AC ACD50.
NAPA should have equivalents.
cdmn
05-09-2002 17:54:47
 Re: Re: TO35 deisel in reply to Jack in NB, 05-01-2002 04:58:38
To Jack in NB. Do you know whether the 35 Standard diesel will fit in place of the original (1949)TEA Standard gas engine? What all would be involved in a retrofit? New starter, filters? What about flywheel and clutch? Front axle support, Radiator? Thanks.
