Leveling arms
gerry
04-29-2002 18:33:05
i have a to30 and the leveling arms on it from top pin to lower pin is 25" on the left one. the right one striped out on me so i got a new one and its shorter. witch ones are the right ones the short or the long ones?
Duner Wi
04-30-2002 06:56:53
 Re: leveling arms in reply to gerry, 04-29-2002 18:33:05
On TO30 2 different leveling box assemblys were used. A short fork (10 1/4 in.) with a long shaft (14 in.) or a long fork (14 1/2 in.) with a short shaft (10 1/2 in.) I purchased a shaft from MF Heritage line in year 2000 for $10.05 US . Part # was 4297V. Can't remember if it was the long or short shaft but probably the long one. The gear was rough cast rather than machined for the leveling box.
Mark Hendershot
04-29-2002 20:10:40
I only use one leveling arm on the right side and a solid non adjustible one on the left side. It seems to work just fine for me. Mark H.
gerry
04-29-2002 22:15:31
 Re: Re: leveling arms in reply to Mark Hendershot, 04-29-2002 20:10:40
right but is the solid long or short? the long one is 25" from pin to pin. and the short one is i think about 22" to 23". i bought a new used adj one and the lower fork is shorter then the one thats on my tractor right now thats why i think the shorter one is the right one. plus when i have my 2 bottom plow on its only about 2" max off the ground with the longer arms. the other thing is this tractor had over sized tires on it and i put the right size back on it that might explaine the longer arms. i think.
Mark Hendershot
04-30-2002 06:31:03
 Re: Re: Re: leveling arms in reply to gerry, 04-29-2002 22:15:31
I have original ones on my TO-30 I will try to remember to measure them today for you. Mark H.
