How to get at the TE-20 Oil filter?
Jeff So. Oh
04-29-2002 10:47:35
Over the weekend I went out to change to motor oil and filter. I had the new filter form NAPA and drained the oil. I then removed the center nut on the oil pan but the cover plate did not readily come off. I was reluctant to start prying.
So just how do you get at the oil filter on a Z120 engine? I removed both nuts but the next step was not obvious.
THanks
Jeff
Dan S (NY)
04-29-2002 16:39:31
 Re: How to get at the TE-20 Oil filter? in reply to Jeff So. Oh, 04-29-2002 10:47:35
Mine was welded on! Had to drop the whole pan to change the filter. Hope yours isnt the same.
Dan
Duner Wi
04-29-2002 12:35:06
Normally the large cover on the bottom of the pan drops off once you take the center bolt off. You should be able to see a thick rubber gasket between the bottom of the pan and the cover on the pan. Gasket is available from MF part # 1750269M1 price as of last year $2.87 US.
If you need to pry the cover off it may be glued on with RTV or something similar. Good luck!
Jeff
04-30-2002 05:01:22
 Re: Re: How to get at the TE-20 Oil filter? in reply to Duner Wi, 04-29-2002 12:35:06
Thanks,
I figured the plate should come off but with out any knowledge of gaskets least having one on hand, I did not want to start prying and banging on it.
I will now take the sledge to it merrily :~)
Jeff
