Seeking opinions on TO-30 hydraulic problem
Scott L
04-29-2002 07:04:05
Background I have a TO-30 that had some problems this winter with the 3PH not raising and sometimes not lowering in very cold temps. Ocassionally it will shake when raised.
I fired it up recently with a backblade on it. The lift came up very slowly and will not come back down. It has not moved an inch after sitting several days.
I opened up the right inspection port and found the following. I was parked on a 10-15 deg downhill slope and the fluid level was and inch below the top rim of the pump (low even for the incline). The fluid was a brackish brown with some solids. With the tractor turned on and the PTO engaged I did not observe and fluid spraying from the cylinder area.
The middle area of the pump where the PTO shaft goes through was generating splashing which I assume was normal given the low fluid. I did not see any turbulance on the outside of the pump area indicating a crack.
I checked operation of the quadrant linkage. Moving the quadrant down causes the linkage to move about 1/2"inch towards the back of the tractor below the area where the return spring is attached. I could manually push that area back a little more but it was pretty stiff. With my hand in the "soup" I was unable to detect movement of the control valve when I operated the quadrant. I was unable to manually pull the control valve to lower the lift.
I am assuming the control valve is stuck which is why the lift won't come back down. I'm not sure how much movement there should be. I am hesitant to just pry at it for fear of bending stuff. Is my best bet to pull the PTO, drop the pump to "renew" it. Could there be another problem?
I think the sluggishness and shaking of the lift may be partially due to low fluid levels and partially due to "sludge" in the valve assemblies.
If I drop the pump should I buy a complete rebuild kit or just assume the lift will perform correctly if it is disassembled cleaned and reassembled? How do I guage the condition of my existing vavle assembly components?
Does anybody have a source/part number for the large pump pan gasket I would need if I dropped the pump. I am only able to find "rebuild kits". Can I just use a generic gasket compound?
This is the first time I have ever worked on the hydraulics so I appreciate your opinions. Thanks for your time.
Scott L
04-30-2002 05:06:57
 Re: Re: Seeking opinions on TO-30 hydraulic problem in reply to rod, 04-29-2002 17:12:31
What's that old saying? "If you want to know the most efficient way to do something give the job to a lazy person. " It sounds like flushing it is worth a shot. Thanks
rod
05-01-2002 04:18:14
 Re: Re: Re: Seeking opinions on TO-30 hydraulic problem in reply to Scott L, 04-30-2002 05:06:57
Hey I am lazy for sure email me direct if you need a manual for your tractor. regards
rod
Scott L
04-30-2002 05:08:20
 Re: Re: Seeking opinions on TO-30 hydraulic problem in reply to Dan S (NY), 04-29-2002 09:22:24
Thanks for the tip. Walt's looks like a good resource.
