TO 20 lift
Brent S.
04-23-2002 19:30:56
I recently had problems with the lift on my 51 TO 20. After tearing into it I found that the 2 sleeves ( not sure of the actual name ) in the middle of the pump had shattered. I need to know how to pull the pump. I've already removed the top and have the plate loose on the bottom but, wasn't sure how to remove it from the pto shaft so I stopped there. Any help would be greatly appreciated.
Dan S (NY)
04-23-2002 20:03:03
 Re: TO 20 lift in reply to Brent S., 04-23-2002 19:30:56
You should be able to just remove the 4 bolts around the PTO at the back of the tractor and slide the whole PTO shaft straight out the back. If you have already removed all the bolts that hold the pump in you may want to put a few back so your pump doesnt fall on the floor when the shaft is pulled!
Dan
Brent S
04-24-2002 13:31:48
 Re: Re: TO 20 lift in reply to Dan S (NY), 04-23-2002 20:03:03
Thanks Dan for the info. I'll try that. Brent
