Positive Ground??
Jim
04-20-2002 19:56:36
I just discovered my TO-30 has a positive ground. Is this right?
Gary IA
04-20-2002 20:13:06
 Re: Positive Ground?? in reply to Jim , 04-20-2002 19:56:36
Yes it is.....typical 6V hook-up
Gary
Jim
04-21-2002 06:44:38
 Re: Re: Positive Ground?? in reply to Gary IA, 04-20-2002 20:13:06
I forgot to mention that it is a 12 volt, is it still ok to have a Positive ground with a 12 volt system?
Duner Wi
04-21-2002 15:10:27
 Re: Re: Re: Positive Ground?? in reply to Jim , 04-21-2002 06:44:38
Depends on your charging circut. Fairly common in the late 50s to have 12 volt positive with a generator and regulator. If you have an alternator then is it much less common but not impossible. If you have a generator and regulator sometime the backside of the regulator will say 12volt neg. or positive.
Jim
04-21-2002 19:05:47
 Re: Re: Re: Re: Positive Ground?? in reply to Duner Wi, 04-21-2002 15:10:27
Yes, it is charging with an Alternator & positive ground, 1952 model. Should I change it to Negitive ground?
Duner Wi
04-21-2002 20:47:10
 Re: Re: Re: Re: Re: Positive Ground?? in reply to Jim , 04-21-2002 19:05:47
If it charges I would not fool with it. If it is a Delco alt. someone went to additional expense to change it to pos. gr.
