Z-134 bare block weight
steve19438
04-20-2002 09:46:32
anyone have the app. weight for one of these?
no head, no crank, no cam, nuthin but block
thanks
Mark Hendershot
04-20-2002 14:33:55
 Re: Z-134 bare block weight in reply to steve19438, 04-20-2002 09:46:32
A Z129 or Z120 Bare Block on a piece of plywood the same size as the bottom with a 2X6 drilled out to protect the studs, 2-12 inch 2x2s under the plywood so you can lift it up coverd in card board weights 149.9 lbs and can go by UPS. The limit is 150 lbs!!! It will be real close. If you remove the studs for the head you can lose a few more lbs. Mark H.
