TEA Starter
Ross M UK
04-18-2002 06:23:51
The Starter no longer works from the gear lever. It does not push the rods under the bonnet. I have to ensure its in neutral and push the starter rods under the bonnet to start it. How do I fix this.
phil
04-18-2002 10:29:10
 Re: TEA Starter in reply to Ross M UK, 04-18-2002 06:23:51
Which Rods are you refering to. I don't think the TEA has any rods under the bonnet. All there is are the terminals and leads to the starter.
Are you talking about a TEF Diesel ??
Ross M UK
04-18-2002 23:31:21
 Re: Re: TEA Starter in reply to phil, 04-18-2002 10:29:10
Its a TEA with a Perkins P3 (3cyl Diesel) conversion. the rods are operated from the starter slot of the gearbox via a little cover in front of the steering column then on to the starter on the right hand side of the block.
