I just bought a Ferguson, but which model ?
Henning S�rense
04-17-2002 13:05:15
I cant find any plate or number near the steering wheel, but there is a serialnumber engraved into the engineblock on the left side: SC110970.
Is this suficcient to identify the model ?
Thanx in advance.
Regards
- Henning
Jim W
04-17-2002 14:35:26
 Re: I just bought a Ferguson, but which model ? in reply to Henning S�rensen, 04-17-2002 13:05:15
Don't know which model of tractor, but that is the motor serial number. It is made by the Standard Motor Company in the UK.
You could have a TEA20 - is it a small grey tractor that starts with the gearshift lever?
Look on the transmission housing just ahead of the differential. Often there are date codes cast into the metal there like 2 5 8, for example. People on this message board can decipher them for you.
Jim
Henning S�rensen
04-17-2002 23:48:34
 Re: Re: I just bought a Ferguson, but which model ? in reply to Jim W, 04-17-2002 14:35:26
Yes, it's a small gray tractor and it does start with the gearshift lever. (and it starts pretty well to)
I located the date codes on the right side of the transmission housing, just below the lever used to raise and lower implements. The date code is: 4 10 5
The first time it was registred was in '57. But it could have been brought to Denmark some years before.
Regards - Henning
Henning Hertz
05-21-2002 01:36:48
 Re: Re: Re: I just bought a Ferguson, but which model ? in reply to Henning S�rensen, 04-17-2002 23:48:34
Dav, Henning...
Jeg har osse en TEA-20'er...
Hvor bor din?
Hilsen Henning
JIm W.
04-18-2002 19:36:43
That would make it a 1955 TEA20. This model was also known in some places as the 20-85, where 85 mm is the piston diameter (earlier it had been 80 mm; when the piston diamter increased the horsepower went from 23.9 to 28 hp.)
This is the same model of tractor that I have, although mine is a 52 (date code 1 5 2). The service manual is still available; check the link below. Best regards,
Jim
