TO30
J Shabluk
04-15-2002 21:00:59
I have 3 problems. First, erratic depth control with hydraulics. Second, gears and pto engage grind even with clutch pushed in at times. Third, oil is leaking from the rear pto, just underneath the pto shaft. Any suggestions or help appreciated.
Rusty
04-16-2002 15:05:54
 Re: TO30 in reply to J Shabluk, 04-15-2002 21:00:59
Here is some help with the easy one. To fix the leak you will need to drain the transmission fluid. Next unscrew the four bolts holding the PTO shaft in the rear of the tractor. The PTO shaft, housing and bearing should slide out easily. If it dosen't slide out easily you have big problems. Then clean the gasket surface and replcae the gasket. And here is a tip from the aircraft factory. When the gasket surface is completly clean; clean it again with alcohol. Rubbing alcohol.
Phil (VA)
04-16-2002 08:32:45
Erratic depth control could be as simple as not having your main depth plunger spring adjusted correctly. Thats the big spring on the rear of the lift cover. Adjust it, according to the manual, and that may fix the depth control problem. Certainly, it's a very easy thing to try. Sometimes if the plunger won't turn the threads may be frozen. Don't force it too much as you could bend the forks inside the housing. Lube the threads with PB Blaster, etc., and try it over a couple of days and it may break free. Sounds like you may have a clutch or throw-out bearing issue too. There is a seal for the PTO shaft you can replace. Check your manual. If you don't have a manual, you can get one from the advertisers on the left of this page.
