TE-20 Transmission Setting S
Jeff
04-15-2002 09:40:42
What is the "S" position in the transmission for?
All I can figure is either- Start or Stationary operation for the PTO. Am I any where near it?
Jeff
So. Ohio
Jone Tveitane
04-15-2002 12:37:49
 Re: TE-20 Transmission Setting S in reply to Jeff , 04-15-2002 09:40:42
Hi Jeff
The S means START (Engine) when you push the gear leveler in to that, the starter motor should engage....
There is a small switch on top of the clutch housing, just undernieth the battery tray....
Regards Jone Tveitane
Stavanger, Norway
Rusty
04-16-2002 18:30:40
 Re: Re: TE-20 Transmission Setting S in reply to Jone Tveitane, 04-15-2002 12:37:49
When you pull the motor you can see how the S setting works. Put the shifter in S moves a switch just under the battery box.
Jeff
04-16-2002 06:27:03
Okay....
My TE20 has a key switch on the dash and a starter button. The key looks new (or at least replaced and the push button looks origional. I start mine with the transmission in neutral, turn the key on and push the starter button. Never put the tractor in "S"
I also only had this tractor for 6 months or so.
Do you think the starting system has been modified to add the key switch?
Jone Tveitane
04-16-2002 12:00:56
 Re: Re: Re: TE-20 Transmission Setting S in reply to Jeff, 04-16-2002 06:27:03
Hi Jeff
YES, i do think that the starter system has been modified.
Originally you would turn the key, and then put it in the S position, and the starter would engage...
But this can have been modified, because of wear in the gear box...If you take the gear handle out of reverse you can be unlucky, and and put it in the S position, and that aint a good thing.....
I know it can be fixed, but i cant tell you how...
Anyway, you should undoo the "damage"... If somone that is not used to the tractor tries start it,and they arent in the seat, that can be dangerous...
This was a long one SORRY;)
