TO 20 pulley and bolt
dave
04-11-2002 09:12:21
I found a crank pulley starter bolt for the TO-20. Will this starter bolt fit into the old crank pulley (without hand crank capability) or will I also have to find a crank pulley that will fit the starter bolt? Also, any tips on getting the old crank pulley bolt out of the pulley-does not have a bolt-type head that I can see? I'm a rookie at this and need some help. Any insight would be appreciated, thanks, Dave.
Mark Hendershot
04-11-2002 09:59:20
 Re: TO 20 pulley and bolt in reply to dave, 04-11-2002 09:12:21
When I remove them I just put a socket and breaker bar and give it a hit with a hammer and they come loose. You might have a adapter bolted over the nut and you can't see it. They all have a bolt holding them on. You can use a puller to pull the pulley off with. Mark H.
