TO30 /w Z120?
Steve Frickey
04-09-2002 20:04:03
I bought a TO30 (At least that is what is on the ID plate) last summer, and As time permits I have been rebuilding some of the hydraulics as the bushings for the hydraulic lift shaft were shot & the control spring plunger was frozen. So for most of the year it has been in my shop. That is all done now & I have moved to the engine. The engine ran fine, so I have just be going over it, inpecting it & changing out the fluids when I noticed the oil filter wasn't where it was suppose to be. It turns out it is a TO-20 engine the Z120. Now I am curious, did some past owner swap out the engine for a Z120, or were some TO30s built with the Z120? Also where can I find or fabricate a seal for the hand holecover assembly on the bottom oil pan? In addition, where can I find a fuel filter stack that goes inside the sediment bowl? Thanks for any help.
Steve Frickey
Duner Wi
04-10-2002 11:07:07
 Re: TO30 /w Z120? in reply to Steve Frickey, 04-09-2002 20:04:03
The big rubber gasket in the bottom of the oil pan that houses the oil filter is available from MF for about $3.00 US. My TO 20 does not have the fuel filter stack in the sediment bowl so I never went looking for one.
Phil (VA)
04-10-2002 07:09:51
By TO30 being on the ID plate, I assume you mean the serial number on the plate cross references to a TO30. My guess is that someone replaced the steering box / dash on your TO20 tractor with steering from a TO30 and left the ID plate on it instead of removing and re-riviting the plate from the orignial onto the replacement. In other words, my guess is that you may have a TO20 with a TO30 steering box (and ID plate), instead of a TO30 with a TO20 engine as you are assuming. Just a thought....
Steve Frickey
04-10-2002 20:32:18
 Re: Re: TO30 /w Z120? in reply to Phil (VA), 04-10-2002 07:09:51
I hadn't thought about this possibility, but it is entirely possible. The ssn on the data plate is 70117, which would make it a 30 from late 1951, the cowling is from a TO30, the engine is a Z120, but I cannot make out anything from the engine ID plate to determine a date. Do you know of any other differences in rest of the tractor that would indicate a 20 vs a 30?
Thanks - Steve Frickey
Duner Wi
04-11-2002 18:44:21
 Re: Re: Re: TO30 /w Z120? in reply to Steve Frickey, 04-10-2002 20:32:18
The only difference I can think off is the TO30 has a more elaborate control valve in the hyd. pump than the TO 20. Look at a I T manual to see the difference.
There may be lots of other differences I don't know of.
Steve Frickey
04-11-2002 21:53:10
 Re: Re: Re: Re: TO30 /w Z120? in reply to Duner Wi, 04-11-2002 18:44:21
Well now that you mention it, I did have the hydraulic lift cover off & I became somewhat familiar with what was inside it. So I did go back to the manual specificaly comparing what it described for the TO20 vs the TO30. It turns out that the TO30 has a safety baffle over the safety valve that the TO20 does not have. My machine has the baffle. The TO20 uses a flat gasket and spacers between the cover and the hydraulic cylinder while the TO30 uses only an O-ring and no spacers. Mine had only an O-ring. So it would appear that I do indeed have a TO30, with a TO20 engine (Z120) -- go figure. By the way I did locate a gasket for the oil pan access hole, from an implement dealer, & I also found a local company that can make them any size. I measured the gasket & it is (as near as I can determine) 1/4" thick, 5 3/4" ID, 6 1/2" OD. Next time I will just have one made. It costs a little more but it is better than driving 40 miles for it. Thanks for everyone's help.
Steve Frickey
Phil (VA)
04-11-2002 07:13:32
I can't think of anything else to check. I do not know of any difference in the hydraulics or brakes, e.g., but maybe someone else can tell us. But I do know if the steering gets water in it, the case can crack in cold weather and sometimes people replace the whole thing rather than just the sector gears, etc.
