TO-30
jim (ky)
04-07-2002 05:54:16
I just bought a TO30 i don't know much about it but i like the looks of it are they good tractors? Thanks very much for your reply.
Phil (VA)
04-08-2002 10:10:46
 Re: TO-30 in reply to jim (ky), 04-07-2002 05:54:16
As the other two replies indicated, they are indeed good tractors if properly maintained. You should get a manual (available on left of this page and other sources). As you come up with specific questions, post them, and someone will have the answer.
Greaseman
04-07-2002 16:11:40
Have fun with your machine, I also have one. It was great to have a low stress project to play around with when I was recovering from surgery! My Buddy would take parts off, then I would clean, scrape, clean, sand, clean, prime, prime, etc.. I was recoverying for seven LLLOOONNNGGG month's, and needed something to play with. I would find out later the engine was lightly seized up, a destroyed radiator, and a VVEERRYY dirty engine. I spent about one full year cleaning almost every thing you can imagine, and then some. I still am looking for grill but think I might have found one, YES!! Good luck with your machine, Keep in touch!Greaseman
Chuck (CA(
04-07-2002 07:50:13
Jim,
Asking the folks on this board if the TO30 is a good tractor is like asking a barber if you need a haircut.
The TO30 is indeed a good tractor. It's comparable to the Ford N series but with a bit more power. They are terrific for mowing, disking, etc. The Continental engine is a workhorse, but it's one weak point is if you let it overheat, the engine could possibly develop a crack. My motor is in the shop right now being rebuilt and having a crack repaired. The previous owner abused the heck out of it. Just make sure you have a working temp gauge along with an oil pressure gauge.
Welcome to the world of tractoring. Life as you know it has just changed for the better. If you have any questions, the good people here are always eager to help.
Chuck
