To-20 and z-134 head
carl
03-29-2002 16:39:31
I bought a TO-20 minus head. The 20 has a z-129; can I use a z-134 head I have? everything looks similar.
Paul (WI)
04-02-2002 19:36:03
 Re: to-20 and z-134 head in reply to carl, 03-29-2002 16:39:31
I can't tell you the exact differences between a 20 and a 30 head, but I know that the 30 head has a deeper area around the valves and combustion area. It might lower the compression.
Duner Wi
03-30-2002 20:11:00
I can not say if it will work but I would look at it real close. Valve guides fit Z120-129-134
Z120 has smaller valves than Z129 134.
Replacement aftermarket manifolds fit Z129 134 145 and maybe the Z120.
Valve grind gasket sets are different for the Z129-134. Good luck !
Dennis in Ma
03-30-2002 13:37:31
the To-20 should have a z120 engine. The to30 has the z129. Can't answer your question with any surety but I THINK the 134 head is different. The 20-30 heads should be the same.
