Wiring a gauge.
Frank (VA)
03-29-2002 06:05:32
I just put a water temp gauge on my TO-20. It has a place to attach a wire to light the gauge. The headlamp switch is just below the gauge. There are two wires to the switch. Can i just run a wire to the switch. If so- to which wire/
Thanks
FB
Duner Wi
03-29-2002 11:47:46
 Re: wiring a gauge. in reply to Frank (VA), 03-29-2002 06:05:32
You want the side of the switch that feeds the headlights. Do a test with swithch off. One side of switch will light your gauge with the headlights off and the other side will not. You want the side that will not light your gauge with the switch off.
Frank
03-29-2002 15:33:39
 Re: Re: wiring a gauge. in reply to Duner Wi, 03-29-2002 11:47:46
Duner,
Thanks, that makes sense.
Frank
