TO 20 axle date codes
Duner Wi
03-21-2002 12:07:22
I have a TO20 with the following date codes on the axle trumpets. 3 4 5 is on left side and 3 5 8 on the right side. My serial 3 plate is missing but I believe tractor is prior to # 10400 or so. If anyone could shed light on this I thank you.
Mark Hendershot
03-22-2002 09:16:17
 Re: TO 20 axle date codes in reply to Duner Wi, 03-21-2002 12:07:22
Not sure if this is what you wanted to know. The TO-20 that these came off was a 1950 and were the original ones. The part # is TO-4013-A and TO-4012-B with another code on a square raised area of 8 1 . Mark H.
Duner Wi
03-22-2002 19:59:41
 Re: Re: TO 20 axle date codes in reply to Mark Hendershot, 03-22-2002 09:16:17
Mark: Thanks for loooking. Sorry I was not clear on question. Casting dates or mfg. date is what I am looking for. I looked at a #56,xxx To 20 today and it has an 8 1 also . I can't make out the date code on other side even with chalk and flashlight.
Mark Hendershot
03-22-2002 20:12:09
 Re: Re: Re: TO 20 axle date codes in reply to Duner Wi, 03-22-2002 19:59:41
Is the code near the TO##s on the caseing? Mark H.
Mark Hendershot
03-21-2002 18:38:45
I will look tomorrow at my 1950 trumpets and see what there number is. Mark H.
